VDB 142 Elephant Trunk HOO
C14 vs. Starmaster 14.5"
Started by Joe Bruessow, 01/29/2004 01:53PM
Posted 01/29/2004 01:53PM Opening Post
This should generate some lively discussion. I currently own a C14 on an MI250 goto mount. It is a nice set up that I have only had for 8-9 months. It was to be the start of a solid CCD imaging system. As many of you who have been in this group for the last 10 years or so know, I have owned many scopes... a 20" dob, 12" LX200, and a host of other smaller SCT's and rich-field refractors. I have just gotten interested in CCD work the last few years and been dabbling in it for about two.
Here is the dillema. I have been searching for a solid compromise scope... solid for both visual and CCD work. The C14's long focal length is a bit prohibitive for Michigan's normally poor seeing much of the year though. I have piggybacked most of my images on the beast. I can easily get a shorter f.l. scope for the mount also and swap out OTA's.
More to the story... I have always loved CZ's mirrors and there is a Starmaster 14.5" goto fully loaded not too far from me that many of you have probably seen available on A-mart. I keep vacillating on what to do. Keep the superior imaging system or get the ultimate visual observing machine.
Over the years, I find myself more drawn to planetary observing and imaging so the Starmaster would do that but hopes of taking those awesome CCD images that others post here would be delayed for a few years. I have even considered a Tom Osypowski platform for imaging with the Starmaster but again, more $$$.
Another aside... I also have a wonderful 10" f/5 Newtonian project near completion with a beautiful Alan Raycraft primary. I am sure it will throw up wonderful planetary images. I could also use that on my MI250 for planetary imaging... and obseve with it in dob mode.
Difficult decisions...
Thanks for your opinions/ input. Not that they will help much... but perhaps they will get me on one side of the fence or the other.
Looking at my toys and their costs... I should be thankful for all that I do have and a spouse that supports it all.
Posted 01/29/2004 04:13PM #1
Hi Joe,
As for the CCD imaging and a C14, check out Ron Wodaski's book. He does not recommend such long focal lengths, until you really know what you are doing, and have super steady skies to go with it. You can have a lot of fun doing CCD images with a much smaller and shorted FL instrument for a long time. As for visual, I like to sit down while I observe, and the C14 lets me do that : )
http://www.astromart.com/messages.asp?message_id=162240&page=
But if you can do it right the C14 will give stunning CCD images, Wodaski's work:
http://www.astromart.com/messages.asp?message_id=22923&page=
But you owe it to yourself to at least check out the Starmaster. If it's a good deal, and you change your mind later, Astromart is always here ...
David Simons
Posted 01/29/2004 04:34PM #2
I went through a bunch of scopes and expense before settling on the SM 14.5 GoTo for the following reasons;
1) Exceptional Optics (CZ Mirror)
2) Extremely well engineered and thought out design (i.e. removeable mirror cell and Hybrid Truss design)
3) Elegant, quality construction
4) No ladders (I generally sit on a bar stool)
5) Light weight components for travel
6) FAST set-up and take down (less than 10 minutes including collimation)
7) Sky Commander/Sky Tracker System is easy to use and very accurate
I live and observe in Southern New England which probably has similar sky conditions to yours. Spending 1/2 hour plus to haul out and set-up a large equatorial mount, get it aligned, etc. was just too much of a back breaking pain. The 14.5 SM has improved my observing pleasure immensely.
Posted 01/29/2004 04:47PM #3
Hi Joe,
I have Starmaster 14.5 with Z-Mirror and GOTO, this
setup has given me some very good lunar and planetary
images and after having said that the rest of my post
may see contradictory.
IMO I would stay with the 10" F/5 Newt. and MI250 , the
resolution of the 10" will be all that almost any seeing
conditions will allow for planetary imaging and the 10"
primary will stay closer to thermal equilibrium.
I have always wondered if the field rotation in my
Alt/Az mount might be blurring very fine details and
of course your MI250 mount would not have that possible
problem.
Wes Higgins
Posted 01/29/2004 06:00PM #4
hi,
I'd keep the MI 250 ..it's a great goto mount ( I have one and love it ) and the C14 and 10" f 5 ota's both of which can be used with the mount. A long FL scope and a short FL scope is a great combination to use visually and for imaging.
The C14 can be made more useable in poor seeing for imaging either by binning the ccd camera or by using a focal reducer.
clear skies,
Larry Citro
