OK, folks, bear with me. I keep going around in circles on this. Just when I was getting serious about minimizing my CO, a friend brought up an argument very similar to one I had made a month or so ago:
At 16" of aperture, the Airy disk is on the order of 0.5 arc-seconds, and the first diffraction ring is on the order of 1.0 arc-seconds. Up to 40% CO, most of the damage is done by throwing light from the Airy disk into the first ring (in fact, a 50% obstructed scope throws nearly an identical amount of light into the Airy disk and first diffraction ring as a 0% scope does into the Airy disk).
So, unless your seeing is better than 1 arc-second (and mine rarely is), you won't often be able to tell the difference between a large obstruction and a smaller one.
One couterpoint is that when observing planets I usually spend 20 min or more at the eyepiece, during which I'll often get several seconds of much better than average seeing. These several seconds are likely to be better than 1 arc-second FWHM, and so if the same is true of deep sky targets I still might be missing out on the few instants that the bar, or the arms, or the tidal tail pops into view.
The first point would argue for a 20" 40% obstructed scope, while the counterpoint might favor a 16" 30%. Anyone swayed by this, or does everyone still line up on the same side of the fence?
Thanks for your thoughts,
-- Jeff.
-- Jeff.
