Philip Imbrogno
Elephant Trunk Nebula
Comments on the Orion 80 ED
Started by ddrake, 01/28/2004 03:22AM
Posted 01/28/2004 03:22AM Opening Post
Ok I've been reading the previous thread on this topic. I have been doing fairly extensive indoor star testing (it's to cold and snowy for the real thing) and have found the following with my 80 ED. There is virtually no false color visible. Only when I use low power with a very bright artificial star do I begin to see the slightest and most insignificant bluish halo. This is for all intensive porposes a true apo.
Sherical correction does show some undercorrection. It's a little more than I'd like to see but still not all that bad. It's maybe 1/5 wave or so if I had to estimate. Comparisons with an ST90 and a minus violet filter reveal when put through the same test about 1/8 wave spherical undercorrection but a very slight about 1/6 wave miscollimation (after recollimating from much worse originally)error. The amount of light taken out of the airy disk with the 80 ED is slightly more than with the 90 if it were perfectly collimated and maybe about the same with the very slight miscollimation. This is an estimate only. The best way to really tell how much the spherical aberration effects the image is to compare airy disk patterns under the night sky with my 18 inch stopped down to the same 80mm using the same magnification. That may be a while after the snow we just got blasted with.
Another issue with this scope is that the balance point is to far forward. To alleviate this I simply removed the focuser and removed the upper screw from the adapter block and lossened the lower one and rotated the block 180 degrees. I then tightened the one remaining screw and found that it was tight enouph and didn't need to drill another hole. Probelm solved.
Posted 01/28/2004 03:13PM #1
Since you removed the focuser, you may want to check the collimation of the focuser to the lens, if you didn't already.
Clear skies,
Tim
