What are a few ways to cut down vibrations on a mount/tripod? Also, I have three questions in particular:
1) I have a spreader on my tripod - Would I want it toward the top or botton, or in the middle?
2) The dovetail rail on the SCT is attached by only a single screw knob to the mount head. Is there some way I can at least plug up the space around the area the screw touches the dovetail rail? Can I use cork?
3) I figured out that four 2.5-lb weights instead of one 10-lb countweight isn't as stable because the weight is distributed across the countweight bar (which is long). I figure I'll get a single 10-lb barbell weight and put it as close to the center as possible (this is an alt-az mount, similar to the GR-2) and lock it into place using my "real" 10-lb countweight. Barbell weight holes are bigger than the counterweight bar though - what can I use to make the hole smaller?
Any help would be appreciated. Thanks!
-Mike
-Mike
