Hello,
I'm in the process of dovetail mounting an old 8" Meade SCT. From what I understood, there would be 3 screws on each fork bracket to remove. I have discovered that there is 1 on each side that has a nut on the inside of the OTA. I got it off the fork easily but still want to remove these side brackets from the tube because they are ugly and add a bit of weight.
What would be the quickest, safest method for removal? Should I remove the corrector plate and reach down or remove the rear cell completely?
Also, I'm a bit torn as to whos dovetail to purchase. Has anyone done this mod to an old LX6? If so, which setup did you purchase?
Any ideas appreciated.
