Iris Nebula
De-fork a Meade 8" SCT
Started by MLasagna, 04/06/2008 04:39PM
Posted 04/06/2008 04:39PM Opening Post
Hello,
I'm in the process of dovetail mounting an old 8" Meade SCT. From what I understood, there would be 3 screws on each fork bracket to remove. I have discovered that there is 1 on each side that has a nut on the inside of the OTA. I got it off the fork easily but still want to remove these side brackets from the tube because they are ugly and add a bit of weight.
What would be the quickest, safest method for removal? Should I remove the corrector plate and reach down or remove the rear cell completely?
Also, I'm a bit torn as to whos dovetail to purchase. Has anyone done this mod to an old LX6? If so, which setup did you purchase?
Any ideas appreciated.
Posted 04/06/2008 06:22PM #1
Ron,
I did this to an orange tube C8 once. I wasn't quite sure about using radius blocks so I bought a pair of cheap orion rings and fastened then to a dovetail plate. A 8" SCT on a GEM is a nice set-up...very versatile.
Posted 04/07/2008 12:41PM #2
Ron Domenici said:
Hello,
Yep. Remove the corrector. Leave everything else alone. Me? I used the Vixen compatible dovetail from Scopestuff.com
Uncle Rod
Time on your hands?
Posted 04/07/2008 04:30PM | Edited 04/07/2008 04:31PM #3
Deforking an SCT--almost sounds obscene. 8)
Oklahoma State University--The University of Oklahoma!--GO POKES!! GO STATE!!
