Jay Messeroff
Lunar & Solar Transits
Dealing w/ a classical Cass's long focal length
Started by jeyjey, 03/25/2007 12:05AM
Posted 03/25/2007 12:05AM Opening Post
I'm researching the options for premium optics in a large Cassegrain. The front runners are an f/8.4 RC or an f/14 classical Cass. I'm purely visual, so the smaller CO (and higher contrast) of the classical Cass suggest it should be in the lead.
But I'm worried about the 5600mm focal length, so I looked through my records to see when I used maximum TFoV or minimum magnification with my current (f/11) 4400mm focal length.
Of course some of the obvious targets come up: the Rosette, portions of the Veil, the Leo triplets, M42, etc. Many of these don't even fit in the field at f/11, so doing a bit more panning at f/14 shouldn't be that big a deal.
But there's another class of target where I needed the higher light density of a lower magnification and larger exit pupil. Examples include the Headphones, NGC2403 and Thor's Helmet. At f/14, even a 31T5 gives barely more than a 2mm exit pupil. I can go up to something like a 55mm Plossl for 4mm, but I'm not terribly fond of the soda-straw views it gives.
What do folks with classical Cassegrains do on low-surface-brightness targets?
-- Jeff.
Posted 03/25/2007 04:53PM #1
Posted 03/26/2007 05:29AM #2
Hello:
I use both the 31mm Nagler and a 55mm Plossl in my 12.5" f/15 classical cassegrain. I kind of like the fact that the exit pupil is small since it darkens the sky for those faint fuzzies and minimizes the effect of the astigmatism in my eyes. But yes, large, low surface brightness objects are harder. Things like the Horsehead Nebula seem harder to get in my cassegrain than my f/6 dobsonian (both using the 31mm). Targets like M31 are just out of the question, and I can only get a part of Eta Carina in at a time.
I suppose the answer is that I don't do anything about it. I still try to see these targets, but they are harder to get and you can't see as much at once. The higher magnification makes hunting for planetaries and little galaxies really nice. Planetary observing is a lot of fun, since a cheap 9mm eyepiece works great with a f/15 scope and gives very good contrast. I also learned how to use a finderscope with my charts to find faint fuzzies. The old "use the Telrad to point in the general direction of X and pan around until you hit it" method doesn't work so well with a classical cassegrain. The real solution, of course, is to convince Mr. Nagler to make a 60mm Nagler with a 4" barrel so that we can get a lower power AND wider fields of view.
Cheers
Mike Connelley
Posted 03/26/2007 07:23AM #3
I've used a 17" f/15 classical Cassegrain at the ASH Naylor Observatory for many years. The focal length is a whopping 6477mm and the maximum true field of view using a 55mm Ploessl or a 40mm U.O. MK-70 is only about 26 arc minutes. However, since the vast majority of deep-sky objects are even smaller in apparent size I've been able to observe many hundreds of them with this scope. The problem nowadays is that the skies at the observatory are growing more light polluted by the minute.
Dave Mitsky
Posted 03/26/2007 02:32PM #4
-- Jeff.
Jeff,
I've used an old VERNONscope 40mm Erfle (70 degree field) on long focal length scopes (C-14, A-P F/12 refractor) and it works well. For many years at Kopernik Obs we had a Tinsley 12.5" D-K Cass that came with a 101mm eyepiece. You may also be able to find a VERNONscope 48mm eyepiece. However, I'd just forget about observing "big" objects with the scope and add a 4 to 5 inch refractor to your setup. You could even mount it on the classical Cass. BTW, you can get a classical Cass from Optical Guidance Systems with Star Instruments optics. There are several others making them also.
George N
