Denkmeier Optical 2" SCT Power Switch Diagonal
Started by DonDurbin, 12/25/2004 03:42PM
Posted 12/25/2004 03:42PM Opening Post
Just thought I would give a first impression of the 2" Denkmeier Power Switch diagonal. So far I have only used it for terrestrial viewing.
Let me also say the Denkmeier site specifically says, "Allows 3 Magnifications With Any Single Eyepiece". It makes no mention of use with a binoviewer. My attempts to use a binoviewer are outside the intended scope of the device.
This device is made for use with an SCT so I checked it out with my Celestron 9.25. I use a Williams Optic crayford focuser with that scope and a Williams Optic 2" diagonal.
For the first test I replaced the diagonal with the Power Switch Diagonal. I started out with a 40mm Optiluxe. That seemed to work pretty well in the X2 mode and in the focal reducer mode except for the secondary shadow. ( I later found that going much over 30mm with the focal reducer resulted in a very visible secondary shadow.) After using the 40mm in Cyclops mode I put in the 2" binoviewers. They worked with the X2 mode but it was probably more like an X3 or X4 mode with the added length of the binoviewer. The focal reducer mode could not reach focus.
The Power Switch ships with a 2" compression ring visual back that is pretty nice. This is a compression ring 2" visual back with dual tension screws for a very stable grip. I decided I would remove the crayford focuser and try the power switch with just the 2" visual back that came with it. Once again the single eyepiece worked fine but was really limited to 30mm or less when working in the focal reducer mode. The 2" binoviewer would not focus in focal reducer mode. I switched to the older shorter 1 1/4" BlackNight binoviewer. The result was the same. I could not reach focus in focal reducer mode. I was really hoping to use the F/6.6 focal reduction with the binoviewer. The 1 1/4" Blacknight has a very short light path so this device as it was shipped to me would probably not reach focus in focal reducer mode with any binoviewer currently on the market.
Even though the focal reducer mode does not work with my binoviewers, I am still looking forward to work with the switch in its original configuration using my Meade DSI camera.
The bottom line is that the Denkmeier Power switch works as advertised with a single eyepiece and it is handy having three powers with the same eyepiece by throwing a switch and doing a little refocusing. The amount of refocusing was less than I expected. When switching from plain mode to X2 or to focal reducer mode the target I was using was still visible. I think I turned the focus knob about three rotations in either direction. The 30mm limit on the eyepiece was a bit of a surprise, I was hoping for much wider views. I would like to try this device on the my clubs 16" SCT and see what power can be used in an F17.5 scope.
The device is a well made optical quality unit and it a great addition for your SCT when used with a single eyepiece with 30mm or less focal length. Comparing it to my Williams Optic diagonal it is extremely similar in appearance. You might also notice that the 1/10th wave 97% reflectivity is also identical in both units
If and when the temperature ever come up above freezing I will use my yardstick target to determine the actual powers of magnification with this device.
Don Durbin
Posted 02/11/2005 10:57PM #1
A 16" f/17.5 newt????!!!!!!
What do you do, set it up next to your house, then
run upstairs to look into the eyepiece through a
second story window?
"Don't drop the banana!"
"Why not?"
"Good source of potassium!"
