I heard that to check proper collimation was to out focus your eyepiece on a star, and if the difraction rings are circular, then you have proper collimation. I did this and all I see is a big blur with the shadow of the vanes and the secondary in it. How do you get the difraction ring effect? thanks
Diffraction rings
Started by Dm3_87, 09/27/2003 11:54PM
Posted 09/27/2003 11:54PM
Opening Post
Posted 09/28/2003 03:07AM
#2
If all you want to do is check collimation, then even a big blur will do. Center the out-of focus bloated image of a star or planet and see that the central obstruction shadow is also centered within the image. I always do this 1st when I bring the scope out for the night. Temperature stabilized optics & lack of turbulance (local and atmospheric) together with high power is needed to define the rings within this bloated image, and their similarity between the outside-of-focus and inside-of-focus images indicates optical quality. If you need to adjust collimation, place a finger in front of the scope and use it's shadow to help identify the proper screw. Ron
Funding Member
