Digital Setting Circles for Discovery Problems
Started by Jay Martin, 11/18/2004 02:38PM
Posted 11/18/2004 02:38PM Opening Post
Hello,
I am installing a digital setting circle set on a Discovery 14 inch dob. I ordered the kit from Discover. I am having trouble with the bottom encoder. It seems (not sure) that the bolt it goes in slips when I turn the mount. I have tried tightening it, but when I do this it is so tight it is tough to turn the mount. Has anyone else installed these digital setting circles and encountered problems? Any advice would be welcomed. Thanks.
Jay
Posted 11/18/2004 06:06PM #1
I like done a set with a 15" Split tube. IF they are the same then this bolt tends to loosen all the time. What I did was to use Lock-tite on the threads and then tighten it until the movement was proper but the bolt was firm. This has held now for quite a while without loosening. Before it would loosen with a few hours of use.
Floyd
