Wizard Nebula
DSC is installed in 2nd scope.
Started by fblue, 04/02/2004 12:26AM
Posted 04/02/2004 12:26AM Opening Post
After 3 weeks of waiting I finally got my encoders from Discovery. I got them installed and set up everything. Had to make a cutout for the incoder to fit into the back of the Alt Bearing which took a while. The Az bearing bolt had to have the center drilled out for the encorder shaft and a set screw hole drilled and tapped. But now I have DSC on both DOB using the Sky Commander. This should be a lot of fun as it makes it faster to find DSOs.
Floyd
fblue's attachment for post 14663
Posted 04/02/2004 05:24AM #1
Floyd,
Nice job on the DSC installation on your 12.5" dob. Another fine example of your work.
Posted 04/02/2004 01:01PM #2
Floyd, question for you since you have the Sky Commander.
I am in the process of adapting my GEM for encoders so I can use dsc's, and the Sky Commander is the one I plan on getting. Because of space/size limitations, I will have to use the US Digital S1 size encoders, and they max out at 4096 ticks. On the dec encoder I will gear it up 2:1, so it will effectively be 8192, but the RA will be direct drive at 4096. Question: On the Sky Commander can you have two different values for the RA and Dec? I have downloaded the manual, and all it says is to input the values, but doesn't mention if you do it for RA and Dec seperately or a single value for both.
Also, will the resolution on the RA be ok with only 4096 tics? The only examples of dsc's in operation I have ever seen were with the higher values.
I appreciate any info you can provide.
Walt
