DSC problem and solution, your opinions please!
Started by go_ahead_ed, 10/14/2005 02:11AM
Posted 10/14/2005 02:11AM Opening Post
Hi All,
My DSC's were not working well with my 12.5" Discovery PDHQ, with the first few goto's falling within a 1.0 fov, but subsequent objects farther and farther out. I discovered (hey, that's almost a pun!) that the hole in the bottom of the rocker box was about 3/16ths of an inch offset to one side, but ok front to back. I plugged the hole and re-drilled it on center and my last time out all objects fell within a 1.0 degree fov all night long. So the problem appears to be resolved. What I would like is your august and learned opinions on my reasoning as to why the 3/16ths offset was a problem. Here goes:
At the eyepiece, with the scope pointed at the horizon, one inch of movement in azimuth = 1.5 degree of movement on the sky (or about the apparent diameter of M42).
This is based on the fact that my eyepiece is about 3 feet from the point in the center of the OTA where the altitude and azimuth axes intersect.
At that radius, a 360 degree circle described by the eyepiece is about 226 inches in circumference. So 360 degrees / 226 inches = 1.5 inch per degree. Therefore a 3/16ths mechanical offset = .25 degree of sky offset.
This value gets worse with the scope pointed up at 45 degrees and higher, since the diameter of the circle (described by the eyepiece when the scope is rotated 360 degrees in azimuth) gets smaller.
Cont. next post.
Ed Moran
Equipment Forum Moderator - Two of Five
Posted 10/14/2005 02:11AM #1
Another way to visualize the problem (for me) was to imagine the scope pointed at an object located on directly on a line of Right Acension when that line is directly, perfectly overhead. The object, for the sake of the discussion, is 45 degrees above the horizon. If I rotate the scope in azimuth _exactly_ 180 degrees (using the encoder output for reference) it should then be pointing at that same line of RA, but on the other side of the sky. But with my 3/16ths offset it would actually be off by at least .25 degree, and probably twice that amount because the scope, having rotated 180 degrees, is now an additional 3/16ths off.
I could be completely wrong about this, of course grin , but the math seems reasonably correct to me. Comments and/or corrections are welcomed!
Ed
Ed Moran
