james carter
North American Nebula NGC7000
Expanding GM-8 load capacity?
Started by Mactruman, 02/12/2005 11:59PM
Posted 02/12/2005 11:59PM Opening Post
Losmandy says the load capacity of the GM-8 is 30 pounds. Can that capacity be increased by adding a more formidable tripod, or a portable pier such as those made by Advanced Telescope? If so, how much additional weight capacity would such firmer foundations add to the mount? And would a firmer tripod or pier add to the overall stability of the mount?
Posted 02/13/2005 02:12AM #1
To increase the load capacity of the mount, you'd need thicker shafts and larger bearings for increased rigidity, plus beefier worms, wheels, gears, and motors for smooth tracking. And yes, a heavier tripod. Losmandy has already done this for you; it's called a G11. wink
David
