I like to get some knowledgeable opinions about making up an eyepiece case. I'm sure all you guys with 50+ eyepiece collections have long since figured this out.
I have a large Dockucil case with the standard, open-cell foam "pluck" insert. Long-term I don't think the foam will hold up. As my eyepieces change so must the foam. I'm think of using the pink builders foam as a substitute. It's cheap, readily available, has different thicknesses, and easier to cut. I think it's poluyurethene based, but I'm not sure.
Does anyone know if outgassing is a problem? Is there a better substitute available that I'm overlooking?
Another issue. Is foam the best way to go? :S I've seen some cases that use cutouts to fit the barrel made of wood or lexan. Is this a better way to go?
Another question I thought of after looking at Floyd's cases. The case I have is very deep, any opinions on laying out the eyepieces vertically vs. horizontally? If horizontally, I can have two layers for the EPs.
Any pics that I can get ideas from is appeciated. Thanks in advance for your ideas and comments.
