Feather Touch Focuser has arrived! :^)
Started by fblue, 11/28/2003 11:24PM
Posted 11/28/2003 11:24PM Opening Post
I finally got my FeatherTouch I ordered 2 months ago from Anacortes! Starlight was way behind in manufacture because of illness.
It is really a wonderful piece of equipment. :^)
Very pretty and it focuses so smoooooooth! I have to admit it was worth the money.
I got it mounted but of course the cloud gods have moved in for the weekend. :^(
Mounting it was a bit difficult as you had to disassemble it each time you adjusted the leveling screws. It took a while but finally got it just right.
I finally found a formula for the offset, It tells where the laser dot should fall on the diagonal mirror in relation to the actual center of the elipse of the mirror.
How to figure offset for Diagonal Mirror in a Newtonian Telescope
Diagonal offset = mirror size divided by F/R X 4 then X 1.414
Diagonal Diameter = 2.6” = 66mm
F/R = 4.9 X 4 = 19.6
66mm divided by 19.6 = 3.3673469mm
3.3673469 X 1.414 = 4.7614285mm
4.7614285mm = .1874574” = 13/64”
Offset is measured from true center of diagonal mirror ellipse away from the primary mirror.
1 millimeter = 0.0393700787 inch
Many of you problably know this already, but for those that don't I just posted it.
Floyd
