Feathertouch base: Tilt or not?
Started by tomhole, 11/24/2004 01:27AM
Posted 11/24/2004 01:27AM Opening Post
I am going to replace my JMI DX2 on my 11" Starmaster EL with a new Feathertouch focuser. Should I get the adjustable base or just the regular one?
TOm
Posted 11/24/2004 01:35AM #1
Tom,
My 16" Starmaster came with the Feathertouch w/o the adjustable base. I found that though I could get perfect optical collimation, the mechanical axis was not coincident with the optical axis. IOW, the laser was off center when the autocollimator showed perfect collimation. The solution was to square the focuser which is a trivial task with the adjustable base.
I heartily recommend getting the adjustable base just to make squaring the focuser easy.
Randy
Randy Roy
Posted 11/24/2004 02:11AM #2
Hi Tom,
I've used both, bases with and without adjustment screws. The adjustable bases are MUCH easier to get square with the world than using shims to adjust. Since the base has four places where it attaches, and three points determine a plan (or in your case plane?) wink , if you shim the base, you'll always be looking for the correct thickness for one of the corners you don't adjust. With the adjustable base, just turn the screws til everything is lined up. Of course YMMV, just MHO.
Dave
Posted 11/24/2004 07:22AM #3
I have bought two of the adjustable base and they are great. Not that much more money either. It is a good idea and it is definitely worth it. I too have found that it is necessary to adjust the base to properly square the focuser.
Floyd
