Iris Nebula
First Light w/ Nexstar 11 GPS
Started by tomdisco, 10/16/2003 02:35AM
Posted 10/16/2003 02:35AM Opening Post
My first light attempt with the Nexstar 11 GPS ended in failure last week when I inadvertantly reversed polarity on the power cord pin, blew the fuse in the DC adapter cord, and was out of business elctronically. I pushed on in manual mode but soon discovered the Nexstar 11 makes a poor dob!
Tonight was my first official first light (with power). I passed up on the GPS Align option due to lots of trees on my northern & southern views opting instead for Auto Align. Since the scope came from an Astromarter in Ohio I expected I would have to enter my own lat/long coordinates the first time but it somehow already knew where it was. After the scope chose its 2 alignment stars and I got them centered I achieved successful alignment on first attempt!
I proceeded to go to several objects with reasonable accuracy (Polaris was a tough alignment star due to trees) but eventually had azimuth slewing problems due to cord wrap. Apparently I had not entered the cord wrap feature correctly. This was an opportunity to shut down, restart, and try Two Star Alignment where I choose the stars. Using Vega & Alpheratz I once again got successful alignment on first attempt. This time I spent a tad more effort getting dead on centering with alignment stars and the results were nothing less than perfect. Go To commands were entered for Mars, M13, M57, M15, M31, Double Cluster, Albireo, M92, and M27. In every instance the Nexstar slewed to center or near center of my 32mm wide angle EP.
After having struggled with the erratic results of an LXD55 GoTo mount the Nexstar 11 GPS is a dream to operate. I spent a lot of time reading the manual before rushing out with the scope and that really paid off. I was honestly expecting major rookie problems with the Nexstar but that proved not to be the case. This is a scope I would recommend to anyone looking for excellent quality in GoTo equipment.
Posted 10/16/2003 10:45AM #1
Hi James: I too am the new owner of a CelestronGPS scope - only the 9.25" model. I moved up from an old Meade 4" reflector which wasn't all that bad - the tripod and mount, however, were not at all adequate. When you aligned your 11", did you compensate for magnetic variation? I did not do that yet and will have to the next time I'm observing as we have a 10 degree variation here in Chambersburg PA USA. If you did compensate - how exactly did you do it. I looked through the manual and it's a bit vague on this point. TIA!
