I have attached a printable picture of an aiming reticle that can be cut out and glued to the bottom of the laser to aid in collimation. My LaserMax did not have this so I just took a photo of a laser that did and enhanced the lines to be darker and then sized it to fit the 1.25" end of the laser. Print it and it should be about the size you need. Just cut out the reticle from the picture and punch out the dark center and glue into place with rubber cement and your ready to go. I find that it make it very easy to find the center of the hologrid when it is projected to the end of the laser now.
Use it if you want to give it a try, it should work for about any laser.
Floyd
Floyd
