Gerald Elkin
House Finch
Fully-illuminated field
Started by Jeff Verona, 12/27/2002 11:20PM
Posted 12/27/2002 11:20PM Opening Post
I know that long focal-length scopes have a smaller fully-illuminated FOV, but I don't have an exact formula. Does anyone have an equation where I can plug in aperture and focal length to get the size of the fully-illuminated FOV? Thanks.
Posted 12/28/2002 03:36AM #1
What type of telescope are you asking about? In a Newtonian, the fully illuminated field depends on the aperture, the focal length, the size of the diagonal, and the distance from the center of the diagonal to the focal plane. In a refractor is depends on the aperture, focal length, and the size and placement of the baffles.
Posted 12/28/2002 09:56PM #2
Thanks for the help. What I'm specifically looking for, I guess, is how large a light cone you can get for a given aperture/focal length combination. For example, suppose I had a 6" f/10 Mak. How large will the image circle be at the visual back? If it's less than 35mm, then it wouldn't make any sense to use a 40mm eyepiece. Anybody have a quick equation for this, or does it depend so much on baffling, etc., that it has to be computed based on the actual design and build of the scope?
