I have a Meade Sn10 mounted on a G11 with the HD tripod. When the scope is pointed to higher altitudes, the eyepiece is about 6'2" above the ground. I'm only 5'9". I'd like to be able to use the scope without a ladder and without turning the scope so the eyepiece is on the bottom. I think I need a shorter tripod.
Looking at a Meade Standard Field tripod that the owner says is only 30 1/2" high. That would bring the scope about 10 or 11 inches lower.
WOULD the Meade Standard Field tripod (with the Losmandy adapter) be adequate to handle the 65 pounds of the mount, plus about 40 pounds of SN10 with Moonlite focuser, ST80 guidescope, QHY-5 guide camera, Nikon D5100, Powermate, dew heaters, 32 pounds of counterweights, etc.?
Thanks for your expertise.
