Good focuser for a dob?
Started by toml, 09/29/2003 11:09PM
Posted 09/29/2003 11:09PM Opening Post
What is the best feeling / working dob focuser THAT WEIGHS LESS than the feathertouch. I guess there's the NGF-DX1 weighing in at 18 ounces versus FT's 21 ounces.
Low profile would be nice. Any moonlite reviews out there? Can't find em. Any experience appreciated.
TomL
p.s. another way of phrasing this question would have been: "any suggestions for a good light focuser for my nesting (hence the desire for low profile) 13.1" truss dob?"
Posted 09/29/2003 11:24PM #1
I have a Moonlight on my 10" dob and like it very much. However, I have to be upfront in that I don't much care for their method of attaching to a curved sutface, ie, a tube. They use a couple wedges and spacers and since the mounting holes are not symetrical to the center hole of the focuser, you have to "square up" the focuser with leveling screws. It works but is a little time consuming to say the least. Once done it should be good to go for a long time, and the focus is very smooth, especially the "slow motion" side.
A friend who has a truss dob with a Feathertouch says the moonlight is as good as his in every respect. However, the Feathertouch units are available with a shorter height if you need/want that feature.
Walt
Posted 09/30/2003 12:45AM #2
The DX1 is a nice focuser. I have the inexpensive DX3 and it is OK too. A dual rate is nicer for most things though and I also am in the market.
The Moonlight is looking good and since I have a flat board tht it mounts to, the mounting is not a problem. However the bolt pattern is different from the DX3 and you must ue a plate. That would not be bad for me because I need a little more backfocus anyway. ;^)
Now I just have to save some more money as I just got the Sky Commander and encoders for my DOB. :^0
Floyd
Posted 09/30/2003 06:03AM #3
I have a Phase4 from AstroSystems; it has a synthetic base so is pretty light (for specs see www.astrosystems.biz). However, I have not installed it yet so cannot give you a first-hand report. I'm sure Ed Taychert can, since he sells it with his Tscope. It's low-profile if you countersink the base part into the focuser board, otherwise not particularly so despite the spec. (I know where you can get one used if you want one; search the Ads.)
As for nesting -- the FT detaches right? (I went through this "calculus" not long ago.)
-- William
Posted 10/01/2003 01:45PM #4
Tom,
I recently added a Moonlite dual rate to my 13" dob and I highly recommend it. The fine focus side is very precise and very smooth. The eyepiece set screw is nylon so it will never mar the eyepiece barrel. It weighs in at 15.8 oz. Moonlite's single rate is lighter yet.
Best regards,
Doug Scobel
