Good laser collimator ?
Started by moutinho, 06/10/2004 07:07PM
Posted 06/10/2004 07:07PM Opening Post
I am looking for a good laser collimator. I have found the following at ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3820516583&ssPageName=STRK:MEWA:IT
Does anyone can give me any advice ?
Andre Moutinho
Posted 06/10/2004 10:21PM #1
1.25" Lasers are not as accurate from my experience as the 2" versions. If you don't have a 2" focuser then it is not an issue.
The main problem with cheaper collimator's is the collimation of the laser itself. You must make sure that it is indeed collimated before you use it.
Really you should check any laser before you use it.
If you bought on of those and did a proper collimation on the laser it would work fine. I did this to a regular version of the Orion and it works OK.
The main problem is that the 1.25" never seems to fit the focuser barrel very well. Too much slop and it is not going to be accurate. This can be overcome with some tape wrapped around the laser to make it fit tightly in the focuser.
Howie Glatter, Kendick and LaserMax are all good. I own the LaserMax 2", Kendick 2" and Orion 1.25". I like the Kendrick and the LaserMax best. But the Orion works when I need a lightweight 1.25" laser.
Floyd
