Since I know a lot of folks are curious about this scope, I'm going to give some initial impressions before I've even had a chance to really see what it can do. I got the scope in on Monday, spent about 35 minutes putting it together, and have been waiting for a clear night to try it. Tonight wasn't clear, but I did get to use it for about 20 minutes before the clouds rolled in. More on that in part 2.
The base is very cheap, very dry, fairly heavy particle board. That much is to be expected. However, it looks suitable for it's task, and probably durable enough for a few years, though I expect repeated dewings will eventually cause the particle board to swell and chip. Replacing it with plywood would be very easy. Apparently this one shipped with the "new" round bottom baseplate instead of the older, tippier triangular one.
The teflon "bearing" surfaces are the smallest amount of teflon that will do the job, and they are single stapled in 3 places on each side of the rocker box. It's crude, but surprisingly effective. The scope turns easily on both axii.
The focuser is a pretty decent seeming rack and pinon with cast metal housing. It's got less slop in it than I've seen on some Crayfords. The 2" to 1.25" adapter fits well with little play, and 1.25" e.ps fit snuggly into it.
The 4 spider vanes are about the thickness of hacksaw blades, and are surprisingly sturdy. These seem much preferable to some of the wider, difraction spike causing vanes that I've seen on competing DOBs.
The silver painted thin steel tube is so short (45") that it's very easy to carry. On it's rocker box base the total height is just 50". At zenith, the eyepiece is centered just 44.5" from the ground. So viewing from a chair isn't just possible, it's *mandatory* if you don't wish to blow out your knees trying to kneel. Oddly, the interior of the tube is finished in a grayish paint that really isn't flat enough or black enough for my tastes. Eventually, I may flock it or texture and repaint the inside.
The whole assembly takes up less than 2 sq. ft. in a corner.
part 2 to follow
Mike Swaim
part 2 to follow
Mike Swaim
