I'am thinking about buying a Hardin 12"dob.Does anyone know were I might find a review of the scope.Does anyone have one that they could give me their opinion of scope?Also is there anyone else selling a 12" dob in Hardins price range?Thanks JD
Hardin Optical 12" DSH
Started by JD Swinea, 02/22/2004 01:16AM
Posted 02/22/2004 01:16AM
Opening Post
Posted 02/23/2004 01:03AM
#1
Jack,
I purchased a DSH 12 OTA from Hardin optical in January. I did not buy the base so I will limit my comments to the tube and associated hardware.
The tube is 56.6" long and just under 14" diameter. The "clear" diameter of the primary is 11 7/8" and the secondary is 2.6". However, the surround on the all-plastic secondary holder adds ~0.2" to the obstruction for ~24% total. The holder and standard three-screw adjustment works OK but the screws dig into the plastic so it is the only real "fix" needed on this scope. Some users add a washer or replace the holder with something better. The spider is heavy enough with metal vanes of the right thickness. The inside of the tube is painted flat black. Down by the primary, the mirror support is 9-point with push-pull locking in an all-aluminum frame that bolts to the end of the tube via 6 machine screws. The mirror is secured by rubber L-brackets to the frame. Mine arrived with the L-brackets secured too tightly, so some adjustment was necessary but not difficult at all to do. The primary is center-dotted, and amazingly enough, the rather small doughnut is accurately placed.
Back at the top end, the focuser is OK (read: not a Feathertouch) with somewhat stiff action but it is good enough to leave alone for now.
Nice touches: compression-ring 2-to-1 1/4" adapter; fully threaded and blackened 2" focuser draw-tube; decent 9x50 finder.
Not-so-nice touches: plastic secondary holder; the tube seam is a little "loose" and as such the OTA is not quite round until sqeezed by tube rings; the included eyepiece set is of mediocre quality.
The net weight from the shipping box is 21kg or ~46lb.
The optical quality of the DSH 12 (for a sub-$1K scope) is nothing short of outstanding. Star testing shows ~1/8th wave overcorrection. In focus the views are contrasty and definitely limited by atmospheric conditions. I had a great view of Saturn last weekend and pushed the power to 450x with no sign of breakdown. At SAC's desert dark site last month M33 showed more detail with less mag than the view in my other scope, a 14 1/4" f7 truss Newt. I was more than a little surprised by this.
Needless to say, I am happy with my purchase. The scope arrived via truck without incident and while the OTA is large, it is just small enough to handle without too much difficulty.
Good luck on your new scope decision.
Matt
Saguaro Astronomy Club
Glendale, AZ
Matt
Glendale, AZ
Funding Member
