John Greenlee
Before and after
HELP my computer is stuck in night vision mode
Started by ddrake, 06/06/2003 10:05AM
Posted 06/06/2003 10:05AM Opening Post
While using SN Pro my computer froze while in nv mode. I had to turn it off to reset it and low and behold it booted up normally but Windows came up still in nv mode. I went back to SN pro to turn it off but nothing happened. It thought it was in normall mode and now can be made to believe it changes but really doesn't. How can I now get my color blind computer back? Thanks.
Posted 06/06/2003 09:39PM #1
Ed,
If you are going to give computer advice at least have him use the correct (Ok, More correct) utility. : ) At the command prompt type: fdisk and select the option to delete the current logical partition. Once deleted power off the PC. Upon power up insert a bootable copy of a Linux / FreeBSD / etc. Disk (CD or Floppy)and proceede to install new OS.
Clear Skies! And good luck Darren!
Well, at least you didn't advise him to get a Mac!
Posted 06/07/2003 12:33AM #2
Before you get real drastic, go into your SN pro software, go to whatever menu turns on Nightvision (Sorry, I'm unfamiliar with how to do it in your software), and turn it nightvision on and off, or just off if need be......It may be that that is all you need to do. For some reason, the program did not clean up after itself.
