Ghost of Cassiopeia
Help on balancing an Eq Mount for astrophotography
Started by ivanong, 11/03/2005 03:51PM
Posted 11/03/2005 03:51PM | Edited 11/03/2005 03:51PM Opening Post
Hi, I need some opinion/help here.
I am doing astrophotography with either a 4" and 5" refractor, with an SBIG STV mounted directly above the imaging OTA. I am using a Tak EM-200.
When I add a finderscope I mount it where the pre-drilled finderscope holes are, which is to one side of the OTA tube, not directly above (can't do it anyway as the STV will be in the way).
My question is balancing the whole setup with the finderscope attached on (I like it on to help me locate some dim objects to photograph). I balance the system on both axes with the OTA horizontal. But when I move the balanced system to point at an object somewhere else in the sky, I frequently find that the balance is no longer valid due to the non-symmetric weight attachement of the finderscope. I find that the STV and tracking are working harder, and are definitely more prone to inaccuracies. In fact, the degree of "dis-balance" is highly dependent on the orientation of the OTA given the attachement of the finderscope to one side.
So, question is, do the experts remove all non-symmetric attachements (i.e. finderscope) when doing imaging, or do they re-adjust the balance of the OTA at each orientation prior to imaging (much better, but more of a pain)? Or do they get a monster hairy mount that doesn't even care about these trifling balance issues?
Ivan
Posted 11/03/2005 08:15PM #1
Ivan,
I balance and image without the finderscope attached. I only attach the finderscope long enough to initialize my GOTO. It's worked for the most part for me.
I also use an EM200 mount.
Eric
