Iris Nebula
High power with binoviewer in short refractor
Started by adamsdp, 03/06/2005 12:57AM
Posted 03/06/2005 12:57AM | Edited 03/06/2005 12:59AM Opening Post
I have a Brandon 94 (640mm fl) and Denk II/Powerswitch/Newtonian OCS. Wondering if anyone has any good ideas on how to get to high power (150-300x) without having to resort to short focal length eyepieces.
With the OCS in high power mode (2.5x), I have an effective focal length of 1600mm. To get to 300x, I would need a 5.3mm eyepiece which doesn't sound like a great choice having read posts about troubles merging below about 10mm and the posts about it being better to magnify as much as possible before any binoviewer prisms to minimize optical abberations. Thanks.
Dave Adams
Posted 03/06/2005 01:31AM | Edited 03/06/2005 01:41AM #1
Dave,
How often do you expect seeing conditions to permit 300x viewing without image breakdown, even with a 94mm APO?
Is not the theoretical limit of your scope around 200x in pristine conditions? A pair of 10mm EP's will put you at 179x, not 150x. Your effective focal length with the 2-arm power switch will be about 1792mm. Remember, your Denk automatically increases the power of any EP by about 12% simply due to the extended optical train. Whatever power a particular EP normally gets in mono mode will yield 12% more in a Denk bino. That's the number you multiply by the 2.5 to get true maximum power with the power switch.
This extra 12% is one of the most commonly misunderstood aspects of binoviewing. Other brands may have slightly different percentage factors. 12% applies to Denkmeier.
I have the Denk Standard and used to have a pair of 10.5mm XL's which worked fine (no aberrations).
Posted 03/06/2005 04:04AM #2
You can also call Denkmeier and ask for the high-power cell (part S), which gives a multiplier of 3.2 with the Power X Switch in its highest power setting.
