Hocky Puck sandwitch GEM mount weights
Started by Tom Mengel, 09/23/2003 05:44PM
Posted 09/23/2003 05:44PM Opening Post
Just an idea (or maybe as a potential web business).
If Hockey Pucks do well for vibration damping why not make a free-weight/puck "sandwitch" to go over the dec. axis shaft and act as the counter weight on a HD GEM? In effect suspend the free weight from touching the dec. shaft with 2 pucks on either side? There would have to be a long "shaft collar" that would go tightly through the center of each puck and the free weight would need to have clearance from the dec. shaft (no direct touching) and be attached to the pucks.
This would create a relatively "dead" (vibration wise) weight that could absorb vibrations from the rest of the mount. If two smaller weights were used on the GEM's dec. shaft you may even be able to "tune out" resonate vibrations from the rest of the mount by moving them into different positions while the total combination still balanced on the RA shaft.
Comments?
TM
Tom Mengel
Moderator Equipment Talk
“Insanity: Trying the same thing over and over and expecting different results”.
Albert Einstein
Posted 09/24/2003 09:22AM #1
Hi, Tom
Give it a try and let us know what happens! I'd rather try something out and see for myself than hold a discussion about whether it would work or not. smile
How about trying a hockey puck between the GEM head and the tripod, and then that same arrangement with and without hockey pucks under the tripod feet?
