I was talking with a friend about collimation tools yesterday. He talked of using the Catseye 2" and how much he liked it. My Starmaster came with one, but I did not get it with the purchase as the owner wanted to keep it.
So I was sitting there thinking of what to do and I came up with an idea. 8) I thought, how about making a 2" Auto Collimator of sorts.
So I took a piece of aluminum sheet that I had laying around a polished a section of it to a mirror shine. I then found a plastic spice bottle that was 2" in diameter and cut the bottom off at the right length. I then cut the aluminum into a 2" circle and drilled a hole through the center. I also drilled a hole in the center of the bottom of the plastic bottle that I had cut to length. I lined the inside of the bottle with self adhesive black felt and then put double stick film on the back of the mirror I had made and slipped it to the bottom of the bottle.
I then collimated the scope using a Kendrick laser and a 1.25" Auto Collimator I already have. Then I dropped in the new device to see how it worked. My mirror is center spotted with a Catseye triangle with the center hole for laser use. The hole I drilled in the aluminum mirror was just the right size to make a black dot just under the size of the center hole in the triangle. The dot was exactly centered in the hole! 8O I then turned the collimation bolts on the primary to put it out of collimation. The dot was not in the hole, which I expected. So I moved them until it was again centered and dang if the other tools did not agree that it was perfectly collimated!
The thing about this tool is how easy it is to use. You are not having to merge triangles or made judgments as to whether the images are perfectly merged, just place the black dot in the center of the hole in the triangle with a slight reflections ring around it that shows if it is not perfectly centered quite well. The hole can be made to just fit the hole in your mirror center spot by increasing the size until it fits perfectly. It is a bit like a Cheshire I guess, but it is built more like the Auto collimator. Here are three picture that show the details.
This was my first attempt and I might build a better one of pipe and cap, but for now it works so well I think I will just use it.
