i messed up badly...
Started by acgtek, 12/30/2003 04:50PM
Posted 12/30/2003 04:50PM Opening Post
in attempting to clean my sct, i used isopropyl alcohol and all that other good stuff. However, as i applied strokes to the corrector, larger and much more visible oily marks began to appear. Now my corrector is smudged so much, it's pretty much like a mirror on some parts of the corrector. Is there something i'm doing wrong?
Posted 12/30/2003 04:51PM #1
Rubbing alcohol commonly available off the shelf in stores contains glycerin or similar oils to make it's easier on the skin.
Posted 12/30/2003 06:18PM #2
Make sure you get as close to 100% alcohol as possible, like 94% or if possible 99% Grain alcohol, not rubbing alcohol.
Yes a drop of Dawn detergent in distilled water will help too.
Use a new cotton ball (large ones) each time you swab. Throw away each ball after it is swabbed only once, very important!
Floyd
Posted 01/08/2004 04:49PM #3
I got the same bad result when I tried off-the-shelf isopropyl as an eyepiece cleaner. A drop of acetone on a Q-tip fixed everything right up,.
Steve
