For about 32 years I have been bugged by not being able to see the crosshairs in my finder scope under dark skies. The finder scope that I have is the standard 8 x 50 straight through supplied with the Guan Sheng 10"/F5.
I believe it is not such a difficult job to illuminate it internally with a RED LED and I have a couple of questions in this regard.
I planned to mount the LED and a small battery in the OTA of the finder with a small switch on the side of the tube, obviously I need to keep these bits out of the light path.
My main question is will the LED provide enough internal illumination if it is mounted anywhere in the tube or does it need to be mounted very close to the crosshairs.
The 2nd question is what sized LED would do the job, I was thinking 3mm would be about right.
Are there any major foreseable problems with this that I should know about.
Thanks in Advance
Clear Skies
John Bambury
Thanks in Advance
Clear Skies
John Bambury
