Inexpensive Mirror Reflectometer
Started by Rod Kaufman, 04/23/2018 01:59AM
Posted 04/23/2018 01:59AM Opening Post
Measuring mirror coating reflectivity can be an expensive proposition especially if you use a commercially manufactured instrument.
I found this ultra-low cost portable method on the web. What do you think of it? Thomas, your input would be quite helpful here:
https://www.sites.google.com/site/photonadroplet/telescope-mirror-reflectivity-meter
Posted 04/23/2018 09:11AM #1
Hi, Rod. It is indeed true that one can ~make~ a very nice specular Reflectance radiometer/photometer with only a light source and detector, and some judicious building of the mount, and one or two simple lenses.
I did a lot of that at work, but always had a nice radiometer head as the detector. (UDT made/makes them and most all are the same and VERY accurate!) Those can be had used for... maybe a hundred bucks? So, I built lots of specialized radiometers. Oh yeah, and filters to select bands. Things to guard against are narcissus [The narcissus effect occurs when the detector, through unintended reflections off internal lens surfaces, etc.], smacking the detector with photons abruptly, and hysteresis. We would typically get accuracies to 0.2%, which is good enough for a lot of stuff. That's 0.2% of the signal, so even high reflectivities are quite accurately measured. That referenced author properly acknowledges that a Reference Mirror is extremely helpful. I built one that looked like a "Doll House" That allowed three paths to the same detector: One direct, one off a reference mirror, and one off the ~test article~, all in rapid succession, without hiccoughing the detector. We used that as a pass/fail QC on coatings, with the reference mirror being one that had been certified as good, using a full-blown spectroradiometer. I have a lot of sketches and pictures of these things, being used. Will look for.
I found my sketch of the Doll House! We then proceeded to (have people) Q/C thousands of mirrors, using the Doll House that I built at home, in my humble shop, on a Sunday. The reason I was surprised to find it... I have hundreds of these sketches, all different configutrations, most then used for specialized radiometric tasks... and most all Quick and CHEAP!
PS also did lots if in-situ measurements of mirrors e.g. inside of telescopes...  FUN!  Tom
Thomas Dey's attachment for post 157061
29-inch Dob in a dome
36-inch upgrade soon
LUNT 80/80 solar scope
FLI 6803 cam
APM 100mm APO Binos
JMI RB-16 Night Vision Binos
Zeiss 20x60 IS binos
Posted 04/23/2018 10:29AM #2
Thomas,
Your "doll-house" concept is quite innovative. The design is highly efficient and user-friendly.
If I recall correctly, I seem to remember an article I read years ago wherein a technician used a "hand held reflectometer" from Cal-Tech to measure reflectivity of a new recoating of the 200" mirror at Mt Palomar. The image in the article showed a tech in a clean suit taking the small gizmo out of his pocket and taking a reading on the mirror surface. I'd sure like to have one of those but I don't even know where you'd find one and I'm assuming they cost a lot, too...
Posted 04/30/2018 05:22AM | Edited 04/30/2018 05:23AM #3
Originally Posted by Rod Kaufman
Thomas,
Just remembered, the context of the Dollhouse was big, flat copier scan-mirrors that we were making for Xerox, tens of thousands. We would do the absolute cal once a day (pantry location) and then use the differential sliding motion platform for the rest of the shift, and one or two more shifts, depending on the work-load. The "hole in the floor" was small, so the two flat mirrors could be ergonomically slid L/R to get Ref/sample1/Ref/sample2/Ref/sample3... without the detector ever seeing broken beam or misalignment. It was a wonderfully-boring job that turned around the measurements as fast as they could go through the trays from coating.
PS: It was FUN having production responsibilities!  Design test-sets, breadboard, build, integrate... and on to the next problem. In a high-volume 24/7 shop, no excuses for procrastination, obfuscation or "not my job." I LOVED it!
Re' In-Situ R measurement. Here, I’ve set up measurement of a GIANT folding-flat. And yes, the light source is a humble laser-pointer. We found that some are stable, and some are terrible. Did the ref/sample1/ref/sample2… as usual, and it worked well. We had considered a little commercial puck thingy… but I looked at their literature and patents, and realized they had built a Lot of assumptions into their design, that would kill traceable BRDF (bi-directional reflectance distribution function) buy-off. So, as usual, we built our own. Nearly all of my concoctions could be used on the production floor, ambient factory lighting. Good design, conjugate baffling, bandpass filters… works wonders!  Tom
Thomas Dey's attachment for post 157211
FLI 6803 cam
APM 100mm APO Binos
