Interesting Astromart Binocular Ad...
Started by jonisaacs, 03/16/2004 02:23PM
Posted 03/16/2004 02:23PM Opening Post
Check out ad #257126
To quote:
"I bought a pair of 12 X 60 and compared them with my 7 X 50's. WHAT A DIFFERENCE! I looked first at the Pleiades. Instead of looking so far away, they looked right up close and filled the field of view. I saw more stars and they were brighter. The 12 X 60s are light and just about as steady and as easy handheld as the 7 X 50. Not much larger either. The FOV is just about the same. 6.4 DEGREES with 12 X 60 as compared to 7 X 50 at 7 degrees."
I find it contradictory that the Pleiades can have "filled the Field of View" and yet still have nearly the same field of view. The Pleiades are less than 2 degrees across so its pretty hard for them to fill a 6.4 degree FOV.
Three possibilities come to mind:
1. The Pleiades grew by a factor of two or so during the night.
2. The TFOV of the 12x60s is not 6.4 degrees, this would imply a 77 degree APOV. Wonder if they are "sharp to the edge."
3. A bit of BS/hype is going down here.
I am also curious about why this fellow is selling these fantastic bino's.
jon
Posted 03/16/2004 04:29PM #1
Probably just that the 12x60's have a smaller TFOV and that the increased image scale (~71%) would be a big difference and increase the apparent seperation by the same amount. I believe the "brighter" realy means "just as bright" since most people never get their eyes past 5mm exit pupil, even when we think we are "dark adapted". The image scale was probably the impresso-factor.
S.S.
S. Sherrod
