Horsehead Nebula
Is possible to track the ISS with a G-11?
Started by franksnow, 07/24/2009 07:37AM
Posted 07/24/2009 07:37AM Opening Post
Hi boys and Girls,
I would like to know if this mount working with the Gemini v.4 can track the ISS on same way that New MEADE mounts can do.
Thanks B4hand,
Frank
Posted 07/24/2009 12:14PM | Edited 07/24/2009 12:14PM #1
Well, I'm not an expert on this, but I'll give it a try. Because of the tracking speed necessary, you need software that will drive your mount independently of the tracking rates programmed into the mount. As far as I know, the only "useful" satellite tracking software is the freeware program called "Satellite Tracker V2.4.9" This software uses it's own track/drive algorithyms to produce a track. It does NOT use ASCOM drivers, therefore the connectivity/support of your mount depends on what prorocol it uses. As far as I know, the SatTracker software it is only compatible with the following protocols: Meade LX200, 200GPS, and Autostar. Celestron Ultima, NexStarGPS, NexStarGT, and CGE/CGEM. If you want more info, go to the Satellite tracker Yahoo user group at (http://tech.groups.yahoo.com/group/satellitetracker/).
