Ralph Ford
M31 with Redcat 51
judging quality of 10" mirror
Started by BABOafrica, 02/24/2013 09:06AM
Posted 02/24/2013 09:06AM Opening Post
I think I pushed my 10" mirror as far as I could. The conditions were both clear and steady. I was using a 3mm Zhummel EP. Since the FL = 1118mm, that would be about mag = 375X. (I had collimated using a barlowed laser.)
I was viewing Saturn almost as zenith in the early morning after the moon had set. I could see the shadow of the planet on the rings (a first for me grin).
I suppose that means the mirror must be good quality -- to give that kind of resolution. Or is this pretty common for dobsonians, no matter the quality of the mirror?
Clears,
Joe
In lumine tuo videbimus lumen.
8O Home-made 10” Dob / Home-made 4” refractor
EPs: Konig 32mm (1.25") / Zhumell WF 30mm (2") / Nagler 13mm T1 / Orion Sirius Plossls 25 & 10mm / Zhumell Plossl 9 mm / Meade MA 9mm
Posted 02/24/2013 05:12PM #1
Clears,
Joe
Joe,
While it's certainly a good sign your mirror can utilize a 3mm eyepiece without degradation of the image, seeing the shadow isn't necessarily a criteria for optical perfection. Star testing, examining the intra and extra focal rings at high power, for symmetry and lack of aberration, is a much better measure of optical quality. The latter takes some time and experience but it's probably one of the best methods you can do in the field to determine optical quality.
I wouldn't get too fixated on it though, just sit back on a good observing chair and enjoy the view!
