Hi Folks, this is a rammble...
- Kowa Highlander Prominar with 9,14,and 21mm ep's(Anacortes)
- Universal Astronomics MACROSTAR (prototype Larry sent me - thanks!)
- Bogen 3036 (ebay - my dad got my old 3036 which I luv, so hunted down used one since Bogen d/c'ed line)
I'm in the Netherlands now - about 30min outside A-dam. I bicycled to the viewing site with the setup loaded into a custom padded pelican 1510 - call me crazy (call me crazier when i get my motorcycle in Tanzania!!)
First-light tonight, typical dutch clear-skies weather: cool, 40F-ish, 5-10mph breeze, rel humid - subsealevel damp (view time was 2hrs before dew buildup was proibitive).
I never saw so much color (the good kind - i hope)! Ive been using my 4"apo and 14.5"newt for a few years, have had handheld binos also. never had context to marvel at contrast in this aspect of stellar viewing until now. I've never heard anyone discuss this about bino viewing - has anyone comments on this, the fact that color viewing is enhanced?
all objects noted close to zenith, at least 45degrees above.
no "false" colors that I can detect on mine as others have reported. This was on Vega and a few nights before on the wanning moon. can see some comma (? - vignetting?) with 21mm eps at edges, about 10% in.
M13, I imagine granularity with 9mm.
M33, faintfaint smear. amazed i could find it to begin with out here in NL
M51, no go (but low on horizon, <45degrees)
M57, impressive, can see central clearing
NGC7000, ok I saw it with Zeiss 20x60 IS outside seattle. just for kicks tried it here, but no luck.
M45, marvelous, icy white stars.
NGC884/869, ok, now I know what they mean by 3-D effect. I stared at it for "hours". Also wowed some folks walking by who wanted a peak.
The spring retention system for the eps is annoying. it takes some force, so you loose the object in sight as you wrestle out the eps. Markus or anyone else out there with these binos reading this - any fixes?
The focus is delicate, you can really hone in.
the Macrostar is nice, about par with Giros that i (or I should say my dad) use with my apos. only wish there was altitude friction control that was easy access (need wrench to adjust it).
the bogens i am bummed. bad dampening, never remembered these as so heavey (then again, never biked with them before when i was a lazy-assed car-driving home-boy). think i might try to find a gitzo (1227, 1228G) - any input?
ok, should i be bummed about the comma/vignetting at edges? On center and about 70-80%out they are crisp.
if i am moved (which i hope to be) will write from tanzania in about 2months.
By the way, i think i am going to post my Zeiss 20x60 IS on astromart. any takers?
sanders
sanders
