LED Lights
Started by nzdmmf, 07/30/2009 03:36PM
Posted 07/30/2009 03:36PM Opening Post
I want to illuminate the setting circles on my mount, since it is a manual mount. I'm doing this the old school way of using it manually. Does anyone know of a source for some small RED LED lights I can mount on my scope mount. Any information would be greatly appreciated......
Thanks
Posted 07/30/2009 03:42PM #1
The quick answer.....Radio Shack!
But if want one of the ultimate sources for just about anything electronic component wise goto www.digi-key.com
Thanks
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Monroe GA
Posted 07/30/2009 04:31PM #2
There is always American Science & Surplus...
www.sciplus.com
They have 20 small red LEDs for $2, but the shipping will make you go to Radio Shack unless you find some other stuff you want.
Posted 07/30/2009 05:59PM #3
Terry,
Although you can make your own LED light system from scratch, be aware that you have to wire a current limiting resistor of the correct value in series with the LED it order to get it to work. An LED alone, connected to a battery will not work.
The big advantages of LED lights are:
1. Almost no heat.
2. Uses very little current.
3. LED's last almost forever.
If you want a semi ready-made LED light system, just go to Wal-Mart and shop around in the automotive and sporting goods sections. For an LED light you can connect to a 12 volt battery pack system, Wall-Mart sells small red LED truck clearance lights which can be cut down and modified to most any use. I modified a two-LED unit to replace the bulb in my truck's dome light to provide dim red light when I open the truck door at star parties. I also made a star chart reading light by taking the guts out of a 120 volt clamp-on headboard reading lamp and replaced the bulb with an 8 LED red truck clearance light. I just clamp the lamp to the top handle of a 12 volt battery pack and have an instant table top red reading lamp.
Another item I found at Wal-Mart the other day was in the automotive accessory section. It's a 12" long self-adhesive strip with an embedded row of tiny red LED's, designed to be attached most anyplace on a car; under the dash, in the glove box, etc. This LED system would be easy to adapt to astro use.
If you want a completely self contained small red LED light, go to the bicycle section at Wal-Mart and buy a battery operated red LED bicycle tail light. These are made to attach to the back of a bike or clip onto a back-pack, and are usually powered by two AAA batteries. Most have multiple LED's and are designed to blink but they usually have a single-LED-on-constantly setting. You can attach it to almost anything with some self stick Velcro and/or a home made holder bracket.
You can also modify one of those single red LED keychain lights for astro use by replacing the coin cell power supply with a larger battery system of equal voltage and installing an on-off switch.
If you can't find an LED light with either a built in red lens or an actual red LED, you can buy a roll of red "tail light repair tape" at Wal-Mart and make most any light red. I also use this red tape to cover the annoyingly bright status lights on my laptop for night use. I can still see the status lights but they are red and very dim.
AS they say, necessity is the mother of invention.
Posted 07/30/2009 06:53PM #4
If you don't want to bother with a soldering iron, just get one of the hat or strap-on "head light" products sold at hardware stores and attach it with some Velcro. I have a head light that switches between white and red illumination and the angle of the LEDs is adjustable as well.
Jim McSheehy
Posted 07/31/2009 11:23AM #5
Thanks
I was faced with the same task...illuminating the setting circles on my Dob. Trotted down to good, ol' Walmart and found a couple of clip on reading lights with long, skinny, flexible necks for less than 2 bucks. A little Rubylith and I was in bidness.
Uncle Rod
Time on your hands?
Posted 08/01/2009 03:32PM #6
As everyone here has suggested...a small red LED will do just fine.
I'd stay away from the high intensity ones as they are bright and annoying - a few 20mA red diffused LED's should work just fine.
You can power them from any voltage provided you have the proper resistor. Use a resistor for each LED. That way, should one of them burn out you don't have the rest of the LED's getting more and more current which will just lead to failure of all lamps.
If I remember right:
Voltage drop, minus supply voltage, divided by current draw, equals resistor value in ohms. I could be wrong, it's been a while - so feel free to correct me.
Phil
