Lens cleaner
Started by maurice clark, 08/21/2003 09:41PM
Posted 08/21/2003 09:41PM Opening Post
Hi all.
I have to try and clean a 100+ year old 10" clark refractor. Since the lens is air-spaced I am reluctant to do it with detergent/propanol in case some of the liquid seeps between the lens elements.
I believe that there is a solution that can be sprayed onto a lens and then peeled off, taking dirt with it. Anyone know how good/safe this stuff is? Also, if it is suitable, where can it be obtained. I am in central Pennsylvania.
The lens is uncoated. (not counting dust, grime etc! :-()
Thanks in advance.
Maurice
Posted 08/22/2003 01:50AM #1
Go to this Yahoo group :
http://groups.yahoo.com/group/oldscope/
There are a lot of knowledgable members. I would be very careful with this antique.
Clear skies,
Tim Hornbeck
Posted 08/22/2003 03:39AM #2
Hi Maurice,
A product matching this description is "EZ Strip" which I bought from Randy Cunningham at Astro Systems. I've watched it being used, and have a can, but haven't used it myself. I try to avoid lens cleaning whenever possible.
The other similar item you'll hear about is collodion. I can verify that it works great on lenses, but I abandoned it and don't recommend it. I never felt safe working with it as it's exceptionally volatile and can be explosive.
If I had such a lens I think I'd be looking for professional cleaning / alignment. Perhaps D&G or one of the other lensmakers would take it on.
Good luck,
Doug
Posted 08/22/2003 02:54PM #3
Maurice,
Sounds like you have a very rare and unique telescope. Perhaps you should be asking if there is anybody that could do this for you. You certainly wouldn't want to risk damaging a prize such as this!
Paul Atkinson
AstroProProducts.com
Posted 08/22/2003 10:31PM #4
I believe that the product you are looking for is called "Opticlean." A web search immediately turns up the vendor Dantronix. I have heard good things about it but you might ask around.
