Ruben Tommasi
Andromeda Galaxy (M31)
Loose nut in Celestron 9.25
Started by DonDurbin, 09/08/2003 01:54AM
Posted 09/08/2003 01:54AM Opening Post
I heard something come loose in my C9.25 last night. When I brought it in I could see a loose nut in the tube. I believe the nut came off a recessed phillips head screw on the front tube ring. I can see that the other screws have nuts and I see one that does not.
I took the visual back off but I cannot reach it with my magnetic pickup and I am afraid of scratching up the inside of the visual back tube if I use a coat hanger with a small wad of tape.
Should I take the fround corrector off? If so how does it come off? I have heard that orientation of the corrector is important.
Any ideas welcome.
Don Durbin
Salem, Ohio
Posted 09/09/2003 07:27PM #1
Donald,
The small nuts that usually come loose inside the C925 are one of the six small nuts ( 3 on each end ) that hold the tube to the ends. 3 of these little screws and nuts hold the rear assembly to the tube, and 3 hold the tube to the front ring that holds the corrector plate. You will probably want to re-install the nut in its original location.
If a front nut is loose, its very easy to make the repair, but you have to decide if you are ready to open your OTA assembly and do the job. Since I opened mine completely and flocked the inside of the tube, I know these 6 nuts well.
To fix it, carefully remove the ring that holds the corrector plate in place, but do not remove the corrector plate yet. With paper and pen, make notation of the orientation of the corrector to the housing. You might find that in the 3 o'clock position is a black mark that is an alignment index from the factory. There are also some small paper shims. Note their location.
Then remove the corrector plate, and gently tip the OTA forward and the little nut will come sliding out. There is NO need to stick anything in the OTA to retrieve the nut. It will definitely slide out along the bottom of the tube. Do not risk scratching your primary mirror.
Re-install it on the small screw on which it belongs, and put the corrector plate back in its original location. Do not over tighten the screws on the ring that hold the corrector in place.
A final caveat: you are on your own if you elect to make this fix. I take no responsibility for your mechanical skills in executing what is a very simple task.
