Ghost of Cassiopeia
Losmandy G-11 nodding/flexture problem
Started by [email protected], 10/06/2005 02:58AM
Posted 10/06/2005 02:58AM Opening Post
Hello:
I have a Losmandy G-11 with a 50lbs 12.5" cassegrain on it. This scope is pretty close to the limit of what the mount can handle; it is both long and heavy. So, it's not too surprising that the scope is less than rock steady on the mount. I would still like the scope to be as steady as possible. To this end, I intened to install a strut from the end of the counterweight shaft to the end of the tube.
However, the main source of flexture is in the RA clutch pad area. I have adjusted the gear mesh to minimize backlash. When I wiggle the scope back and forth (not enough to make the clutch slip, just enough to simulate wind shake) in the RA direction, the motion seems to be at the interface at the clutch pad. When I wiggle the scope while my thumb is pressed over the RA setting circle and vernier, I can feel a little differential motion. The motion has a resonant frequency of about 2Hz. I have found that reducing the friction on the clutch (with he knob at the back of the RA shaft) reduces this instability, but then the scope is free to move on its own. My question is: what can I do to reduce or eliminate this instability? Will replacing the clutch pads with the ultra-high molecular weight stuff help? Is there some home brew fix that I could try? I suppose I could get a heavier duty mount, but I'd prefer to try the less-than-$10000 options first!
Cheers
Mike Connelley
Posted 10/06/2005 07:20PM #1
You're asking a lot of it. Until recently I had a 7" f/8 refractor mounted on a G11 and no matter how well tuned, the moment arm of the large heavy scopes is a bit "in control" of the mount. I also had flexure that was not backlash related. I dont think the clutch material would have made any difference. I think the big heavy scopes simply flex parts of the mount.
My solution was an older AP900QMD and it was far, far less than the $10,000 you mention.
Posted 10/06/2005 10:20PM #2
This is from somewhat fuzzy memory... but I think
the RA shaft inserts into the upper RA assembly
and is fixed there by a single hex set screw.
I would check whether this set screw is loose.
I had similar screw on the Dec axis come loose
with similar symptoms.
m87's attachment for post 96986
