A question for you barlow experts out there . . .
I understand from several sources that you can obtain additonal magnification from a given eyepiece by backing it out of the barlow slightly, thereby eliminating the need for closely spaced eyepiece focal lengths. Is this the case?
I generally use a 6" f/5 scope with 2x Ultima and 3x Antares shorty barlows. If I back out an eyepiece (say a 12.5mm or 10mm backed out 10mm/1cm), is there a way to determine the approximate magnification gain through this method.
Thanks for any advice you can provide.
