Meade 16" Mirror Weight
Started by stuper1, 04/05/2007 03:59PM
Posted 04/05/2007 03:59PM Opening Post
Thanks for the info on the thickness of Meade's 16" parabolic primary mirrors. Now I need to know the weight, if anybody happens to have that info. Thanks!
Posted 04/05/2007 06:07PM #1
Well, I don't have a Meade mirror. But I do have a 16" Orion mirror. It's about 1.6" thick, f/4.5, and Pyrex. It actually measures slightly larger than 16" in diameter, like 16.125" to 16.25", if I remember correctly.
The weight is 26.5 lbs.
Hope this helps. I don't know how accurate you need to be. If you're building a scope, you don't need to be as picky about the weights on the bottom of the scope as you do on the upper end.
