Ruben Tommasi
Andromeda Galaxy (M31)
Meade product line
Started by FcEfAd, 08/22/2004 08:15PM
Posted 08/22/2004 08:15PM Opening Post
I'm totally new to telescopes and am considering purchasing a fairly expensive model (at least for me). I'm considering the LX-90 or the 8" LX200. I've been doing a little research and have noticed that these models have been out for a while, since ~2001. Does any one know when Meade may be releasing their next product line which will replace either of these models? How often do new models come out? My intention is to purchase a scope that will last me a long time and I'm concerned that something new may be right around the corner.
TIA,
Doug
Posted 08/22/2004 08:20PM #1
The LX90 replaced the LX50. It will probably be around a for a good long while as it is the only "entry level" GoTo SCT they have.
You'd be safe with any of the LX200 SCT's as they are the flagship scopes of Meade. You wouldn't go wrong with any of the LX200's, though keep in mind anything over 8" will be heavy and the 12" and 14" are monsters to move.
Posted 08/22/2004 08:48PM #2
Wow, you guys were fast to reply. Thanks for your advice. BTW, what other brands would you recommend that I consider? In my (limited) research it seems that these two models are at the top, not including cost which has been noted to be higher than the competing brands.
Doug
Posted 08/23/2004 07:02PM #3
In a way, both Meade and Celestron have come out with new product lines, such as the LXD55 and LXD75 series of EQ mounted scopes. These lines also offer GOTO, but there have been questions raised about the build quality of these mounts. Celestron has come out with their CGE series, with a much sturdier mount and also a much stiffer price tag.
If you're interested in a SCT with GOTO I would suggest the Celestron 8" GPS as it is lighter than the LX90 (which I have and which is a very good product). Also, the optical tube of the Celestron is made of carbon fiber rather than metal which apparently cools down a little bit quicker than the Meade SCT.
Posted 08/24/2004 03:10AM | Edited 08/24/2004 03:16AM #4
The LX200 has been around since 1992 or 1993. (i know, I bought one in 1993 and still have it). The only thing I see happening are software and maybe some slight equipment upgrades. an LX200 as well as an LX90 will be usable for years. If you plan on astrophotography get the LX200, if not an LX90 will meet your needs quite well. Good Luck. BTW anything over an 8" is a pain in the butt to set up, beleive me, I hardly ever set up my 10" and this was the reason that I also bought a smaller scope. An 8" nexstar GPS and an LX90 are about the same size.
