I really want to get a C9.25 for it's great combination of aperture, optics, and relative portability. Mainly for the portability reason, I want to get the lightest mount that I can that will still provide reasonable stability. Lower cost doesn't hurt either. It doesn't have to be a go-to mount. Does anybody have any good suggestions for a mount?
Mount for C9.25
Started by stuper1, 04/02/2005 12:54AM
Posted 04/02/2005 12:54AM
| Edited 04/02/2005 12:54AM
Opening Post
Posted 04/02/2005 03:10AM
#2
I had my C9.25" on a Vixen GP-DX and then a Vixen Sphinx. Both these were rated by the manufacturer as 22lb load capacity. For widefield views these were ok, but high power studies on planets was frustrating, especially when you had to focus. The moment I touch the focuser the image would shake violently. I would think if you want light weight and portability mounts like these will work but you need a remote focuser like Meade's if you want to do planets and double stars at higher magnifications.
Good luck, Ivan
Good luck, Ivan
Posted 04/02/2005 01:37PM
#3
I think it really depends on what you want to do - if visual only with just the basic accessories you would probably be fine with the gm-8, gp-dx, or even the eq6/Atlas. If you start using heavier accessories, or want to do photography, I'd move up to the ci-700/G-11/CGE type mounts - well worth the extra $. The cg-5 is way to light IMO.
Posted 04/05/2005 10:51PM
#4
Check out the Discmounts. I have a C9.25 and have tried various mounts and after a few years just got a Discmount DM-6. It is a great mount and can't say enough about how easy it is to use and setup. It is also very stable. I have seen more deep sky objects from my light polluted front yard in the last few weeks than I had for years due to the new mount and Sky Commander. Only drawback is that they are not cheap but it is built to last a lifetime and I can't imagine anything going wrong with it. A lighter, lower cost option is the Unistar which I think is a excellent choice for a lightweight mount that is very easy to setup and use.
Funding Member
Sponsors
- OMI OPTICS USA LLC
- Matsumoto Company
- RemoteSkies.net
- FocusKnobs
- SellTelescopes.com
- APM-Telescopes
- kwtelescope
- astronomy-shoppe
- BBLABS LLC
- Astromart Customer Service
- CarbonScopeTubes LLC
- BW
- Waite Research
- Anacortes Telescope
- Desert Sky Astro Products
- Vernonscope
- AstroMart LLC
View all sponsors
