Moving the Primary Mirror Forward
Started by StarGazer_2003, 03/01/2004 08:14PM
Posted 03/01/2004 08:14PM Opening Post
I'm having problems not being able to rack my focuser in any further than being able to BARELY use a 25mm eyepiece with my Canon EOS camera - anything smaller and I can't move the focus in far enough to be able to see anything. I got a response in one of the other forums that I needed to move my primary mirror forward to push the focus point out a little bit further and I was wondering if anyone has done this before and could give me a few "do's" and "don'ts" before I get started. I understand keeping my hands off of the mirror surface and all but would appreciate any input that anyone might have. I guess I should mention it's a Hardin Optical 8" Dob also. Thanks in advance.
Kerry
Posted 03/01/2004 08:25PM #1
Try doing it with the collimation screws. Turn all 3 of the screws a few turns so that mirror moves up the tube (probably clockwise). Then recollimate, and during collimation only move the screws in the same direction you already did (i.e. don't move it back down during collimation). You should be able to get at least 1/4"-1/2" or so this way, which may be enough, and it doesn't require touching the mirror or drilling any holes....
If this is only a problem using your camera and not for visual use, and you can't adjust far enough with the collimation bolts, try using a barlow or powermate.
Hope this helps,
Jarad
