Iris Nebula
My EM 200 thinks is in Austalia
Started by marzulloj, 11/30/2009 12:57AM
Posted 11/30/2009 12:57AM Opening Post
Hi, I have had a tak em200 and have had no problems with it. Last night I turned it on and it seemed it was not tracking. The stars were moving out of the field of view. I turned the motor off, and the stars were still moving out of the field but at a slower rate.
I realized that it was running in reverse, for the southern hemisphere. I live in New Jersey, not Australia.
To turn the Tak in southern mode, you turn the computer standby switch on at the same time you hold switch S1 down.
When I did that the mount kept the stars in the field and tracked fine.
The problem will not go away no matter how many times I shut the power off and turned it back on. It should be in northern hemisphere mode, when it is first turned on. But it is not, and it tracks as if it were in the south right off the bat. I have to switch to southern mode to make it track.
I have not changed power supply or anything. It always worked fine for the past two years.
Have you ever run into this problem? How do you fix it? I am at a complete loss.
Thanks.
Joe.
Posted 11/30/2009 12:30PM #1
If there is an internal battery in it try changing it. I have seen the small memory circuits "forget" settings because the coin type battery that powers it has lost its power. I have heard of low power in the internal battery cause a variety of different issues because it looses different bits of memory settings. Usually a stored setting reverts back to a default (or sometimes something totally different).
Hope this helps
Buck
Posted 12/05/2009 07:28AM #2
To enable the Southern Hemisphere mode, you have to press 2 buttons at once and do a bit of digging.
If the handset was bumped or accidentally pushed against something that might account for it.
I'm unfamiliar with the EM200, but a quick search on the web for the manual should explain how to reverse the "error"
Peter,
In Australia smile
[COLOR="Blue"][/COLOR]
12" GSO Dob., Meade 102 APO, 13x50 Binos
Tak, Tel & Pent EP's
Portamaount of pain, HeQ5
