I all... I am a long time amateur astronomy (30+ years) getting my first permanently installed scope in a roll-off roof observatory. I have purchased a 14.5" classical Newtonian which will be housed in it (on Astromart!
. The pier that came with it is about 7 or 8 inches in diameter (and weighs about 80 pounds!) We are having a concrete floor poured, with a separate concrete base which will be poured into a hole in the middle for the pier to be bolted to.
Here's the big question..... How deep should we dig the hole?
I assume it should be a few inches or so wider than the base of the pier. The scope if f4.05 so it's a very short system and will not need to be very high at the top. (The pier is 22 inches long.) This should help with stability, but it is a very heavy scope, with a fiberglass tube and large cast iron fork mount.
Suggestions?????!!!!!
Thanks! and Clear Skies to all!
