New Ultima 11" user with questions
Started by daveraw, 06/01/2004 07:04PM
Posted 06/01/2004 07:04PM Opening Post
grin [COLOR="Navy"][/COLOR]
OK so I started out with a Meade ETX and really liked the limited views and started to read these forums before my next scope purchase. I took your advise to heart and found the best "light bucket" I could afford.
The result is a 5 year old Celestron 11' Ultima with starbrite coatings on a stock tripod from someone 5 miles away. The package came with Beyers gears, 7x50 with lighted recticle(doesn't seem to light8-(), 2" diagnal, hand contoller for focus and declination although declination doesn't seem to work, and 3 stock Celeston 1 1/4" lenses ( 35MM, 18MM and 10MM). All Manual controls work flawlessly and there appears to be no image shift or collmination issues although it does have "Bob's knobs".
Initial views with the scope here on Long Island were great. Jupiter showed clear horizantal banding and 5 moons, and the Moon was spectacular with the 35 MM lens.
So now for the advanced newbie questions..
Cleaning ?
The scopes front lens has a few smudges that don't seem to effect performance but could be cleaned and the 2" diagnal has some foreign matter. What should I use, or should I get it to the local camera/scope shop for a professional cleaning.......... if I use the local shop what should this service cost
Declination motor ?
When the scope was demoed the PEC and declination seemed to be running off the 9 volt. Since it came home the declination drive doesn't seem to be operational although the moto-focus is fine with the hand controller. any ideas?
Lenses ?
I've got the 3 Celestron lenses mentioned above and four Vixen Lanthanum lenses from my ETX (6MM, 12MM, 18 MM, and 24MM) and a 2X Barlow. All lenses are 1 1/4". From your professional opinions what is a must have for this scope. Use will be basically planetary, and lunar with some nebula as conditions and light pollution allow.
Thanks in advance for your time and replies
Regards
Dave
Posted 06/01/2004 09:08PM #1
Cleaning of the Corrector Plate should be done with care and caution. This can be scratched and streaked so you need to know how to do this.
Floyd
