Not sure where to post this, but...
Started by eric_w66, 12/29/2005 05:46AM
Posted 12/29/2005 05:46AM Opening Post
Ok, in reading one of the forums of a game I play online, I came across these gems of misinformation. While I know they're wrong, I'd like to know the "facts" as it were of the matter:
Moderators: please move to wherever you feel this useless but funny (to me at least) post belongs.
Poster #1 (this is regards to Sniper Scopes on WW2 era sniper rifles):
This is a lie. (Note: this is about scopes seeing better in low light)
No matter what type of glass you use with a scope, you lose some light. maybe not a bunch, but you LOSE light when looking through a scope.
Its like looking through binoculars at night, you see nothing but black until you look at a light source.
I just took my WWII era russian PU scope (used on wwii russian sniper rifles) outside and looked through it. its 8:40 PM right now, and I couldn't even see the reticle inside the scope. I live out of town 6 mi.
I pointed the scope (took it off the rifle) at my neighbors house, and could see the lit up windows, but had to put the reticle right on the window before I could even see it.
I also took a modern, simmons scope outside and looked, I get the same results.
EDIT: the fact that you can use a tank scope, or any type of scope at night, or even see your front sights on a rifle is unrealistic. Night time, is DARK. you shouldn't be able to see past 50m clearly in full moonlight.
And then (same person defending himself):
I'm sorry, but you don't gather extra light by looking through a scope.
When light hits the first lense on the scope, some of it is reflected.. there are more than 2 lenses in a sniper scope, and there is reflection on all of them. thus, you lose light collection.
Your naked eye is going to collect more light than any non-nightvision scope.
and binoculars are no different than sniper scopes or telescopes, with the exception that sniper scopes have a thin wire crosshair in them.
in low light conditions, like sunset, you're going to be able to see better at range, but that's because you're looking through a scope. the image you're seeing is magnified, not the amount of light.
there are no WWII era scopes that you'd be able to see anything clearly through at night with. (excluding the late war IR scopes).
And again...
Give me some reason WHY a rifle scope collects more light than your naked eye.
I've been hunting in moonlight conditions many times before, and I'll tell you straight up you'd be just as well off with a rifle that had NO sights, as with a rifle with a scope.
I'm sure you've seen pictures from the business end of a sniper rifle, and you've heard abot "Scope glare" right? that's what I'm talking about. the front lense of the scope REFLECTS (Diverts) light from entering into the scope. then You've got 2 or 3 more lenses that the remaining light has to go through, which is further reflected.
Go on Ebay, buy a wwii scope ($300) and look through it in low light conditions, and at night. i garuntee you won't very well in low light, and that you won't see jack squat at night.
And this one is nice, talking about transmission rates heh.
here we go.. from the Leupold scope company (MODERN scope makers that make high end scopes for the united states military snipers.)
This is about "light transmission" (the light that makes it through the scope to your eye)
"this coating system optimzes light management and maximizes light transmission to the eye, providing an exceptionally bright and crisp sight picture with sharp contrast, even in lowlight conditions. In some.. leupold.. riflescopes, total light transmission can reach 98%..."
98% in a MODERN HIGH-END TACTICLE SCOPE.. Not a WWI or WWII era scope. note that number isn't over the 100% you see with your naked eye.
I doubt the british, or anyone for that matter, during either world war had the technology to make a scope that is more clear or brighter than a leupold is today.
And finally, a couple different people:
You gain no light from a scope. You only loose contrast because of dispersion and light because of reflection. Everything the lenses do, is magnifying objects.
F.e. if you are looking through a 4x scope at something at 800 meters it appears as big as it was 200m away, but the light from the object still has to travel 800m until it reaches your scope. If you additionally collect light from other sources, it only will light up the whole picture at the price of contrast/sharpness. The amount of light from the emitting object (or the one reflecting it) doesnt increase, just because u are looking at it through a lense.
And another person chimes in:
Actually, this will depend on the front lens size.
Your brightness ratio is found by dividing the lens aperature by the magnification. If the lens at the front is large enough, then it will deliver more light to your eye (even after loss due to magnification and absorption in the glass) than would enter the iris normally.
For this to work, though, unless the magnification is very low you need a farking HUGE front optic.
Brightness ratio?!? My C8 with a 200mm main lens and a 77x eyepiece gets a score of 2.6 or something on that.... a 30mm rifle scope at 10 power gets 3?? It does better than my scope! We should all form a giant conglomeration of riflescopes to view the stars!
Posted 12/29/2005 11:47AM #1
Brightness Ratio = Exit pupil = the diameter of the beam/pencil of light exiting the eyepiece.
F10 scopes with 1.25 inch eyepieces are limited to something around a 3mm exit pupil at max FOV. An F5 scope, say an 8 inch Newtonian, can have full 7mm exit pupil with a 35mm eyepiece, of course the magnification will be suitably reduced to about 29X...
This is why "rich field scopes" are fast, generally F4 to F6, they maximize the light the eye receives.
jon
