WR 134
Observing Chair idea, power, the whole setup
Started by highrolla7, 09/28/2003 04:23AM
Posted 09/28/2003 04:23AM Opening Post
Hello all,
I know some of you are like me and cant spend the 180.00 or so for an observing chair. Well here is an idea: Thanks to the people on an egroup for the home depot fliptop mechanics table. I customized it a little bit to make it work perfect. I cut the bottom part of the legs where they curve off, then cut down the center bar around 3-4 inches. It adjusts by a lever under the seat. Very slick and total spent: 35.00. I found some "constellation" fabric (which actually glows in the dark) at walmart and a perfect shaped pillow around the house. Had the girlfriends Mom sew elastic around the edge of fabric to make it removable. A very easy and cheap way to have an observing chair,not to mention very comfortable!!
The power is a jumpstarter (everstart) 300 amps w/ 12volt dc power. 40 bucks!! Works great, and if your car battery dies, your set!! I used it w/ my Meade lx90 for around 5 hours or so and still said high charge. No other accessories were used. For those of you w/ an 8 inch sc, a case at walmart also works great.
With these ideas, you may be able to put some of that hard earned cash toward eyepieces and other toys. Thanks, T. J.
highrolla7's attachment for post 9559
Posted 09/29/2003 03:48AM #1
The Starbound Chair is about $170, the Apogee Clone which has a max height of about 24 inches is $70 I think, certainly another alternative for those looking for a less expensive solution.
jon
